Tractor Talk Discussion Forum
ID engine MF
JohnPaul
07-31-2005 10:03:01
I have been told that the engine ID is behind the injector on my MF 135. With some cleaning I found a series of numbers "37111460" X and just below that "GNN1942". It also looks like a small plate above the longer number says "L22" I have found the plate on the other side that tells me that this is an "AD.3 152 Perkins" I just want to know what year it is and what number I use when looking for or ordering parts.
TRC
07-31-2005 10:45:28
 Re: ID engine MF in reply to JohnPaul, 07-31-2005 10:03:01
I don't have much information on those engines, but if you post over on the MF board you might run into someone who can help you out. Check the serial number of the tractor itself and you will be able to get the exact year. The engine parts should be fairly common regardless of the year of manufacture.
JohnPaul
07-31-2005 12:33:21
 Re: ID engine MF in reply to TRC, 07-31-2005 10:45:28
Thanks
That has been the issue, I can not find the number. I may have found it but it will take some brush oil remover to get it. Most numbers are hard to even read. Thanks again for the help
