Tractor Talk Discussion Forum
OT.... NASCAR Engine Build
Chuck (CA)
07-31-2005 18:49:19
Was just watching the Speed Channel and there was a competition sponsored by Clevite that pitted two Nascar engine building teams against each other. The deal was starting with a bare Ford block (V8), how fast could the two teams assemble the engines and have them running. MAN!! Just over 18 minutes, both teams had their engines fired up. The judges then tore the engines down to make sure all the torque specs were correct. It was great!
So, the question is... How long does it take you to put an engine together? Me? About three weeks. ;-)
Chuck
Rod F.
08-01-2005 19:10:26
 Re: OT.... NASCAR Engine Build in reply to Chuck (CA), 07-31-2005 18:49:19
I can see that time for a team, with all the parts ready to go together, everything previouly mic'd and plastigauged. Assembly is actually the second quickest part of the job. Disassembly is generally the quickest. Most of my time is eaten up with cleaning and inspection.
I think the last engine I did, several years ago, was about 70 hours from start to finish, which included removal and installation in the tractor. That wasn't pushing too hard, but also just a 3 cylinder. There's not really a lot too them.
Rod
dr.sportster
08-01-2005 14:19:51
Takes me all winter.But do you really think thats how fast they build a Daytona 500 engine where each and every aftermarket part is checked and tested as far as can be.I bet it takes more than a week to do and test a set of heads.They should have hit the race track.Then it would be a real race.A dyno challenge at the end at least.Then again same guys change tires in seconds.
BigMarv1085
08-01-2005 05:08:25
If you rebuild engines as many times as a nascar mech., you will definetly be fast. Most of us this is a job that we occasionaly do. If it is my money that I'm investing into a engine, I'm going to make sure every part is checked for defects, cleaned and installed per specs. Therefore I'm going to take my time.
Torque Question
08-01-2005 03:36:08
Interesting post but I have a question about the judges tearing down a built engine and then checking for correct torque. I remember my high school shop teacher telling me that once a bolt or nut is torqued say to 75 pounds, that you have to loosen it off to make sure it is 75 pounds by retorquing it. If you wrench on a nut that is 75 pounds already with your wrench set at 75 pounds, you will go over the 75 setting. Maybe I'm not explaining this correctly, hopefully someone will know what I mean. Maybe I'll try a separate post on the subject later. Anyways, I wonder how the judges did their check.
TommyT
07-31-2005 22:46:48
I started one Sept. 16 1998. Will let you know.
TommyT
Keith-OR
07-31-2005 21:51:20
Most of the Time it is under 10 minutes!!! But I'll be damned if someone doesn't takes it back apart before I get up in the morning..Or was I just dreaming!!!!LOL...Keith
Weirsdale George
07-31-2005 21:43:10
Depends on whether you want it to run ten minutes or ten years!
NC Wayne
07-31-2005 19:24:45
If your talking about having every part lying there waiting to be put on, all gasket surfaces cleaned and ready to go together, etc then it typically takes me about 4-5 days for an engine like say a 6-71 Detroit. As you can imagine the more complicated the engine arrangement,(ie- the more "accessories" hanging off it) the longer it takes, especially if I also have to rebuild the blower, several oil coolers, etc etc. If you count all the time spent tearing it down, cleaning/degreasing everything, doing all the running and ordering associated with getting all the parts, etc then I'm right up there with you at 2-3 weeks.
MN Scott
07-31-2005 19:42:16
 Re: OT.... NASCAR Engine Build in reply to NC Wayne, 07-31-2005 19:24:45
Yep, three weeks to three month's is about right for me, all depend's on shop space and motovation.
TDK
07-31-2005 20:42:28
 Re: OT.... NASCAR Engine Build in reply to MN Scott, 07-31-2005 19:42:16
I gotta go along with Scott.
