Tractor Talk Discussion Forum
Thread stripped in lawn mower head...
Mike Burdick
07-31-2005 20:16:26
Well I guess it’s my turn for some bad luck. I replaced the spark plug in my lawn mower and apparently I tightened it too much and stripped the threads in the aluminum head. What is the best method of repair? Is it possible to get a little larger plug and rethread or will a helicoil work?
Thanks in advance
MarkB_MI
08-01-2005 02:49:03
 Re: Thread stripped in lawn mower head... in reply to Mike Burdick, 07-31-2005 20:16:26
Pull the head and helicoil it. If you don't want do it yourself, any automotive machine shop that does head work will do it for a nominal charge.
Bob
07-31-2005 20:37:50
Heli-Coil or threaded insert bushings work GREAT.
Or, if it it a common engine, replace it with a good used head from a mower boneyard.
