Tractor Talk Discussion Forum
Oil Coolers
RandyR
08-01-2005 13:31:07
Hi Folks, it's o/t but I just got a new SUV (Aviator) with the 4.6 liter V8, 300 hp, 32 valves. It uses 5w20 oil. Would an engine oil cooler be advisable in hot 90+ deg weather? Would the oil be getting too thin?
And what's a good cooler to use?
Burnie
08-02-2005 03:40:05
 Re: Oil Coolers in reply to RandyR, 08-01-2005 13:31:07
We have long hot summers down here in Aust. Nobody I can think of runs an engine oil cooler although a lot run trans coolers for towing.
txgrn
08-01-2005 17:54:50
Might check your owners manual. Most at least recommend a 30 in the viscosity numbers at the temp you're talking about..... like 10w-30.
Mark
Fawteen
08-01-2005 15:51:19
Unless you tow a lot (boat or camper or whatever) I wouldn't bother. Modern engines are designed to run hotter.
If you DO tow, I'd get an oil cooler AND a trans cooler.
JMHO, YMMV.
