Tractor Talk Discussion Forum
belly mower tractors
Tom R
08-02-2005 07:42:44
I'm a heavy fellow (350 lb) thinking of getting an older tractor with a belly mower to mow several acres of grass around my country home. (rolling ground in southern Indiana)
Are there any particular models or features that I should look for?
leland
08-03-2005 20:43:19
 Re: belly mower tractors in reply to Tom R, 08-02-2005 07:42:44
there is a AC c in the paper here for 1750 with a 5' woods.
fluggie
08-03-2005 06:01:06
I have a Farmall A with the IH kit that includes the Woods belly mower but also, front end loader w/2 buckets, rear blade, 1 bottom plow and fork lift tines. I use this thing for all these jobs and attachments and find it very handy. Live Hydraulics were added to accomodate all this so I got levers all over the place.
Galen
08-03-2005 04:57:18
8N works wonders around my place for mowing and a LOT more. I'm disabled (knees, hips, back), 6'7" and about 260. - MUCH easier to get on/off than the Super A.
jack kade
08-02-2005 13:01:23
Another point, you could do the same job on a standard Farmall A, or Cub/Cub Lowboy. I'm sure there are other brands that offer small utility tractors that would do the same job.
jack kade
08-02-2005 12:35:47
The "Super A" was updated to the model 100 in mid 50's, then later updated to the mod 130, then the 140. All are basiclly the same tractor; and should do the same job. At any given time there are usually several 140's listed on this site's "Tractor photo ads". Start by checking there.
VAJerry
08-02-2005 08:03:10
At 6'2" and more pounds than you I use my Farmall Super A with a 6' woods belly mower. Does a great job.
Tom R
08-02-2005 12:14:17
 Re: belly mower tractors in reply to VAJerry, 08-02-2005 08:03:10
Jerry,
Thanks for the opinion. Is it the offset that makes this a good mowing tractor for big folks, or is it some other feature? In this area, there don't seem to be many super A's on the market. Do some of the newer (numbered) models have the same features that make the super A a good mowing tractor?
Jerry Cent. Mi.
08-02-2005 09:42:54
I had a cub cutter on a Cub of coarse and hated it. I had to pressure wash the inside of my rear tires after every use.
jlray
08-02-2005 13:35:00
 Re: belly mower tractors in reply to Jerry Cent. Mi., 08-02-2005 09:42:54
Jerry are you located in Centreville? If so e-mail me. I work in Sturgis, have a house in Schoolcraft(selling) and am moving to Mendon. Thanks jerry ray
jray@penguinmolding.com
INCase
08-03-2005 09:45:38
 Re: belly mower tractors in reply to jlray, 08-02-2005 13:35:00
Jerry Ray. Get back to work! ha ha
Myron
