Tractor Talk Discussion Forum
560D and haybines.
Loren
08-04-2005 21:16:53
Wondering how much of a load a 9' haybine is for a Farmall 560D? Talking grass hay, sometimes real thick, sometimes not. Is there maybe 15hp to spare while running the haybine without getting into the "wish I wouldn't have" zone? Thanks for indulging my fatasizing. :>) Loren.
Leroy
08-07-2005 07:44:34
 Re: 560D and haybines. in reply to Loren, 08-04-2005 21:16:53
Pulled Case 555 9' with 28 HP Farmall H
VerMN
08-06-2005 12:09:55
I pull a NH 492 haybine with my 460 and have been in some heavy canary grass. The tractor never really seen a load. The 560 should play with it
(Before the NH haybine it pulled a Int. 990.)
Sorry, you have no excuse to trade tractors. (or buy another)
Loren
08-05-2005 22:36:28
 Thanks, Old you gave me an idea. in reply to Loren, 08-04-2005 21:16:53
I have a 77 Standard. Instead of getting a bigger tractor, for now maybe I'll look for a moco and run the 77/moco in a parade with the Case swather. Course the first moco I found that's price do-able is a Vicon discbine, probably need more hp for that bird. :>(
Steve (Magnolia, TX)
08-05-2005 08:07:05
My uncle (who just so happens to be named Loren, too) uses a 560D for his mower... which is a 9' NH... I think.
So does my cousin (his son)
Shouldn't be a bit of a problem...
Steve
old
08-05-2005 07:55:37
I pull a NH 460 MOCO with an oliver 77 38hp tractor so a 560 should just play with it
Nebraska Cowman
08-05-2005 07:10:28
Oh you'll love it! I cut with a 656 (same engine) and 14 ft swather all the time. Oh yeah, mine is tuboed and walks and talks! But yes, I have a neighbor that has a 560 gas and have used it on a 14 ft machine too and it does just fine.
Farmer Gene (NW WI)
08-05-2005 02:47:48
I pulled a 469 and a 479 for years with my 560 diesel, right now I"m using a 489 with my 460 with no problems. I"ve cut peas and oats that would make her snort some, matter of fact I"ve got bigger tractors that I could use,(806, 190) but I prefer the 460, can see the sickle and what"s going on better.
Jimmy King
08-05-2005 09:33:06
 Re: 560D and haybines. in reply to Farmer Gene (NW WI), 08-05-2005 02:47:48
I cut some grean graze for a guy once, had some up land and a little branch bottom. on the up land it was about 3 ft. tall in the bottom it was as tall as the muffler on the 460D. I was using a 479, in the bottom I was in 1st gear and making smoke, but that old 479 just kept eating it.
Jimmy King
08-05-2005 01:58:56
We pulled a 460,469, and479 for years with a 330U 35 hp
Loren
08-04-2005 21:22:44
 Addition. in reply to Loren, 08-04-2005 21:16:53
I work rough fields so the ground speed may very well be below what normal outfits run. I see that NH states a 35 hp tractor requirement for the 488, but you guys may have some real world facts that supercede that. Thanks, Loren.
