Tractor Talk Discussion Forum
Blades of grass popping through asphalt..
Roy Suomi
08-07-2005 19:34:23
I can fix most any problem with equipment . But , this has me most perplexed... What gives with a fragile blade of grass moving asphalt like an alien being and popping through 5 plus inches of asphalt..I've been to 2 county fairs and a heifer breeding but I ain't never seen nothin' like this.Does anyone out there have a reasonable explanation for this phenomonom . Thanks..
George in Biloxi
08-08-2005 11:28:44
 Re: Blades of grass popping through asphalt.. in reply to Roy Suomi, 08-07-2005 19:34:23
Plants grow one cell (mostly) at a time. Their growth is a form of hydraulics. You know how strong hydraulics are. The area needs to be scraped down good, sprayed, rebuilt and like the others said, compacted good. Life will find a way.
George
jake3x
08-08-2005 08:44:04
I cut a tree down to asphalt a driveway within 2 weeks shoots were growing through. 2 summers of roundup every time 1 came up finally killed the durn thing. The drive was compacted and rolled and the root ground down.
Fred Martin
08-08-2005 08:08:09
Ever been to Canada? Where they have the Canadian Shield.....lotta rocks and you can see a tree growing right out of the crack in the rocks...with about a pound of dirt there. Growing things are tenacious. When North Korea had a famine, the leader advised the people to eat grass. Have we been missing something? Fred OH
Ludwig
08-08-2005 07:27:33
I suspect BBx has it right. Plants are amazing in their tenacity and ability to grow in places they've got no business...
That said asphalt will last longer on a good base thats been properly compact with a compactor and not just a roller. Recycled pavement makes an excellent base particularly if its hit with a compactor. If you can get a sheepsfoot roller on the base and then put down recycled pavement, hit that with a compactor, then pave and hit that good (real good, not state crew "good") with a roller it'll last a long time.
BBx
08-08-2005 05:11:15
I suspect the grass is growing down thru it rather than up thru it. The tiny seeds get into any crack they can find and with a little water set roots. I have occasionally seen some plants around here growing in the concrete on top of overpasses. A little dirt and sand, a crack, a little water, a seed, and a then plant.
Steve/TN
08-07-2005 20:13:46
Survival of the species. Yesterday, while driving on the interstate in Memphis, I happened to notice two similiar phenomena(sp). One was a 2 foot tall sycamore tree growing from beside one of those big concrete divider barriers where they are doing constrution. Growing out of asphalt and concrete? The other one is a vine that is growing up through a metal street light pole. The vine grows up throught the hollow pole and comes out the top. The pole has to be 30 feet tall. It does this every year.
Harley
08-08-2005 07:56:55
 Re: Blades of grass popping through asphalt.. in reply to Steve/TN, 08-07-2005 20:13:46
Where is it and is it fenced? I could use the pasture, Harley
