Tractor Talk Discussion Forum
brown lawn
chris sweetland
08-09-2005 09:35:40
my lawn is burnt out i water it and havent mowed it for a month and it dosent help but its not my whole lawn its olny half of it thats whats strange to me any sugestions as to how to help my dieing lawn?
Scotmac
08-10-2005 06:51:17
 Re: brown lawn in reply to chris sweetland, 08-09-2005 09:35:40
Chris....your yard isn't dieing, unless it is a newly estabished yard. It has just gone dormant. It's Mother Natures way of protecting the grass. When you get enough rain to sustain itself, it will green up again. You might want to give it a shot of 10-10-10 long about October to replace the nutrients it has used while under stress.
tlak
08-10-2005 06:00:20
In CA they painted their lawns.
Dave 2N
08-10-2005 04:44:17
Don't worry-a good rain and/or September showers will bring in back with a vengeance. In the meantime, just go to church and give thanks that you are spared the lawn mowing temporarily.
Don-Wi
08-09-2005 21:32:10
I'd say, just let it go!!!! It don't bother me none if I only have to cut once a month. I really don't have the time anyway, so every spare minute I can save it's spent doing something else that's more important...
Donovan from Wisconsin
NC Wayne
08-09-2005 19:13:16
Mine's growing so fast I can hardly keep up with it. I didn't get a chance to cut for two weeks this last time and it was well over 8 inches high in somemplaces.....Just be glad yours is dying and you don't need to cut it....I've got half a mind to pour mine solid with concrete and paint it green, now if only I had the money to do it..... .Seriously though, Good luck getting yours greened back up
Mike Van
08-09-2005 15:43:13
Still mowing every 8 days here in Ct. - No fertilizer etc. Whatever God has time to grow, I mow. If the man with the grubs would mail me a few, I could get a break -
upred
08-09-2005 15:36:05
I have the same problem in my lawn, I watered it and its still brown, but when I walked over it I noticed that I was soft, not soggy just soft, I gave a little tug on the sod and it pulled loose. I started to pul back some of the sod, and I found grub worms - LOTS of them, they ate the roots off - I need to put down some grubex, then reseed HTH Rick
Joe MD
08-09-2005 13:33:31
Our grass in Maryland is growing like it is June. Can barely keep up.
You might have bugs.
Buster
08-09-2005 12:44:13
Pray for rain!
DRL
08-09-2005 12:39:37
Here is SE Kansas, everything is brown. Got a small shower yesterday, but it's effects are gone now. Only green place is where the lateral lines run. Normal for August. Will probably green up mid September just in time to get frosted.
toolman
08-09-2005 11:55:24
mines like that , every year when we go for a while without rain and lots of heat, where there is lots of topsoil it stays green, where there is rock underneath it is brown,i first thought it was the water table dropping and where the rock was the ground wouldn,t hold any moisture, it may be that of that because of the rocky ground it heats up hotter than where the topsoil is, don,t know just guess, seems to come back in the spring though, and watering doesn,t help much.
Nebraska Cowman
08-09-2005 09:48:45
Look under the thatch, I bet there is bugs or grubs.
ebbsspeed
08-09-2005 12:36:14
 Re: brown lawn in reply to Nebraska Cowman, 08-09-2005 09:48:45
...or a natural gas leak. That will definitely make a spot in your lawn brown.
Iriquois Indian rain danc
08-09-2005 09:42:08
N/T
Bill in TN
08-09-2005 13:42:18
 Re: brown lawn in reply to Iriquois Indian rain danc, 08-09-2005 09:42:08
Contact your county agricultural agent. He should supply you with a soil test kit and many publications on lawn care. A soil test will tell you what, and how much fertilizer, lime, etc you need to apply.
My guess is either you have un-balanced soil, or an insect infestation of some sort.
Basically, you probably need to fertilize with a fertilizer containing insecticide. You may want to get some that has weed killer in it as well. I think it's to early in the year to do much good now, probably better to wait till mid september, and plan on over seeding at the same time.
chris sweetland
08-09-2005 18:22:06
 Re: brown lawn in reply to Bill in TN, 08-09-2005 13:42:18
oh yea no bugs i dug up the septic the other day (by hand my back hoes broken) and didnt see one i checked other places and none it is olny the grass on the slope not the flat spots thats burnt if that makes a diffrence
