Tractor Talk Discussion Forum
WD 45 Diesel
Jon Feldman
08-09-2005 20:28:28
Just wondering what a WD 45 Diesel with Good sheet metal, needs tires,is not stuck but has not run in 8 yrs.Wide front I found one and have no idea what itis worth!Any good guess would be much appreciated!
Mile/wa
08-10-2005 06:41:23
 Re: WD 45 Diesel in reply to Jon Feldman, 08-09-2005 20:28:28
Go into it figuring the head is cracked,which is fairly common on that engine,most can be repaired by a good machine shop,but it's not cheap. The $1000 figure is a good place to start,it should bring that as salvage.
John (MO)
08-10-2005 06:34:41
I would think you would be pretty lucky to get it for $1000 unless it has a cracked block or head. They are very popular with AC guys. At a good auction I would expect it to bring $1500 to $2000.
havvey
08-10-2005 04:39:29
haven't keep up with allis prices latly but would say $1000 based on what you said exspect to have $2000 in it with tires and running/serviced if nothing major is wrong.
just me
08-11-2005 08:51:34
 Re: WD 45 Diesel in reply to havvey, 08-10-2005 04:39:29
Are the diesels rare or were alot of them built. And is it the same as a gas engine block and so on?
Dr.EVIL
08-11-2005 09:18:34
 Re: WD 45 Diesel in reply to just me, 08-11-2005 08:51:34
Diesels are 6-cylinders, 262 CID if I remember right.... gas engines are 4-cyl.... 226 cid. Same deal on the D-17's.
Bob N.Y.
08-11-2005 16:14:01
 Re: WD 45 Diesel in reply to Dr.EVIL, 08-11-2005 09:18:34
The D-17 diesel is 262 ci. The WD-45 diesel is a Buda 230, same as a Cockshutt 40 D.
