Tractor Talk Discussion Forum
Farmall H--Trans input shaft pilot bearing
Randy SE-MN
08-12-2005 06:03:48
Gentleman...I was wondering if it is possible to change out the trans input/output shaft pilot bearing of a Farmall H through the top with the belt pully unit removed. Of course the drive shaft is disconnected...any thoughts??? Randy
Randy SE-MN
08-13-2005 05:53:20
 Re: Farmall H--Trans input shaft pilot bearing in reply to Randy SE-MN, 08-12-2005 06:03:48
John and Tom, thanks for the info, always good to hear from experienced folk.
TomHath
08-12-2005 18:17:00
By an unhappy coincidence I have the cover off mine right now. It looks like you could pull the shaft out the front to replace the bearing. It might be as much trouble as taking the cover off though, by the time you get that bolt off the end and line things up again. Doesn't seem like it would hurt anything to try, worst case you'll end up taking the top off anyway.
Allan in NE
08-12-2005 06:13:25
Randy,
I think the easiest way is to drop that belly pump and come up thru the bottom, isn't it?
Gives you a little room to work that way.
Allan
Randy SE-MN
08-12-2005 12:19:54
 Re: Farmall H--Trans input shaft pilot bearing in reply to Allan in NE, 08-12-2005 06:13:25
Allen...I wasn't referring to the clutch/flywheel pilot bearing...I was referring to the input/output shaft where they join under the trans cover. I've changed several with the cover off, I was wondering if anyone had "pulled a rabbit out of their hat" and had changed one with the cover on.
John M
08-12-2005 18:46:34
 Re: Farmall H--Trans input shaft pilot bearing in reply to Randy SE-MN, 08-12-2005 12:19:54
Yep,done it once.HOWEVER, it seems like I couldnt get something all the way out and had to work the housing around it,maybe the long drive shaft,I dont recall.
