Tractor Talk Discussion Forum
Super C alternator?
monte
08-12-2005 06:48:27
Is there a trick to get those two wire alternators to charge. One wire goes to the battery and the other to the meter. Seems like I have read sometimes they need alittle help to go. We just bought this C and it wasnt charging. So before I take it off thought I would ask. Thanks
Bob
08-12-2005 07:28:24
 Re: Super C alternator? in reply to monte, 08-12-2005 06:48:27
I assume you are referring to the common Delco 10SI or 12 SI alternators.
Connect the alternator's large output stud to the ammeter.
Make a jumper wire to connect the little terminal on the side of the alternator, marked "2" over to the large output stud. This is the voltage sensing lead.
Connect the #1 terminal to a source of power that is switched on and off with the ignition switch.
In this line, you must have a diode (1N5008 works great, end with white and towards the #1 terminal), or an "idiot light" with a #194 bulb (or equivalent).
If you do not use a diode or light bulb in the "excite" line to the #1 terminal, current can "backfeed" from the alternator into the ignition circuit, causing the engine to keep running when the ignition switch is shut "off".
(An oil pressure switch, or a resistor can also be used, but the diode or the "idiot light" are probably the easiest to obtain, and the cheapest ways to do this, and work well.)
BobM, over on the Farmall board, grciously makes his diagrams available. You should be able to find a diagram close to what you need. Here's the link:
monte
08-12-2005 10:26:47
 Re: Super C alternator? in reply to Bob, 08-12-2005 07:28:24
Bob; Just looked number 2 lug is broke off down in there, so I guess I will be taking the alternator off. Ill bet also the number one wire goes up to the switch not the meter, hard to see with the battery in. Thanks Monte
monte
08-12-2005 10:14:42
Thanks Bob. Yes that is the one. They ran the heavey wire from the big stud to the battery. They do have a short jumper wire on the stud also but one side not hooked to anything. The small wire from lug connection goes through a diode to the meter I think, didnt take the battery out to get a better look. Diode seems all right checked with ohm meter. Meter shows discharge with lights on so i think thats all right. Put my voltage meter on battery no different with alternator running or not. I will look at the those diagrams thanks very much. Monte
