Tractor Talk Discussion Forum
1010 john deere front wheel wobble
weum
08-12-2005 07:11:36
I have a 1010 john deere, when driving on the road in 5th the front tires start to shake back and forth real bad..its a wide front end and the front wheel bearings are good any suggestions?
buickanddeere
08-12-2005 13:30:08
 Re: 1010 john deere front wheel wobble in reply to weum, 08-12-2005 07:11:36
Pull the grill and jack the front wheels off the ground. Fill gearbox with fresh synthetic grease. Tighten the set screw down until the steering wheel binds and drags a bit. How much toe in? Take out for a test run.
xragman
08-12-2005 11:55:26
YOU need to increase the caster angel of front wheels. I never had a 1010, so I can't say how to do it.
RAB
08-12-2005 10:05:18
Won"t reduce the play in the system, but what pressure are you running your fronts - a reduction might improve matters if they are on the high side.
Regards, RAB
thefarm@llion.org
08-12-2005 07:59:34
Yes, your steering is worn out somewhere between the steering wheel and the bearings. Check for slack at some point or all the way through the system. Its there..
