Tractor Talk Discussion Forum
Starter Generator
Tim KD
08-14-2005 12:15:45
Although I have several tractors, this is not exactly a tractror question but I"m sure someone knows the answer anyway. I was helping a friend with a club car that has a combination starter/generator. The starter works fine but the it does not charge the battery. Brushes and field windings all read fine with any ohm meter. If I ground the field winding while it is running which I thought should call for full charge I get nothing. It would help to repair it if I knew how it worked in the first place. Any help would be appreciated.
Thank,
Tim
HTR
08-14-2005 16:32:47
 Re: Starter Generator in reply to Tim KD, 08-14-2005 12:15:45
Try this link.
ezyed
08-14-2005 13:15:04
Tim be sure to remove the field wire from the terminal before you ground out the terminal, if you don`t you will burn out the voltage regulator. When you ground it out it should slow the engine down or even stall it out. It hapens to be the same starter/generator that is used on Harley-Davidson,Ezy-go ,columbia. Do you have continuity on the terminal without the wire hooked up? If so then you have a bad wire or bad regulator Hope this helps PS `94 and up use a solid state regulator.
