Tractor Talk Discussion Forum
600 WORKMASTER
RUSTY P
08-15-2005 13:13:54
SOMETIMES ON MY TRACTOR WHEN TRYING TO CHANGE GEARS IT GRINDS.I TRYED AJUSTING THE CLUTCH BUT STILL HAPPENS ALSO WHEN ON A HILL AND TRACTOR NOT RUNNING WHEN I PRESS ON CLUTCH IT WONT ROLL. THINK I NEED A CLUTCH? THANKS RUSTY
Dan
08-15-2005 13:42:30
 Re: 600 WORKMASTER in reply to RUSTY P, 08-15-2005 13:13:54
Sounds like a stuck clutch. Block the clutch down overnight, or a few days if you can afford to and see if it unsticks. If that does not work - go to the 9N/2N/8N message board and do a search of the archives for "Stuck Clutch" and you will find pages of ideas from others to fix this ranging from semi-safe to dangerous.
If you are not going to use your tractor for quite some time, it is a good idea to block the clutch down to the foot board to keep this from happening.
Good luck,
Dan
RUSTY P
08-16-2005 03:36:27
 Re: 600 WORKMASTER in reply to Dan, 08-15-2005 13:42:30
THANKS DAN I'LL GIVE IT A TRY
