Tractor Talk Discussion Forum
alcohol to clean injectors??????????
BSer
08-19-2005 17:44:10
I occasionly add a pint of ATF to the diesel fuel in my Dodge to clean the injectors. today a parts man suggested rubbing alcohol..... ..what good would it do?
NC Wayne
08-19-2005 19:53:48
 Re: alcohol to clean injectors?????????? in reply to BSer, 08-19-2005 17:44:10
The only use I've ever heard for alcohol mixed with a fuel is to pick up moisture. Typically a diesel system has two fuel filters, with the primary being responsible for removing any water in the fuel, so I can't see a need for alcohol in a diesel tank. if you want something that works good to put in diesel to clean the injectors, NAPA carries a product called Sea Foam. Dad used it in his service truck around the 50,000 mile mark and swears it ran better when that tank of fuel had been run through.
Davis In SC
08-19-2005 18:02:15
Most diesel makers state "No Alcohol", or warranty is void.. It destroys the lubricity of fuel, & can score or seize pump parts.
