Tractor Talk Discussion Forum
Homemade 3 point hitch?
Dick N.IL
08-21-2005 08:58:19
Has anyone built a 3 point hitch for a non-3pt hitch tractor? Looking for someone to share info., plan, photo etc. Have experimented with one on my 39 WC, some success, some drawbacks!?
JMS/MN
08-22-2005 07:22:35
 Re: Homemade 3 point hitch? in reply to Dick N.IL, 08-21-2005 08:58:19
All 3ph specs are at www.asae.org.
buickanddeere
08-21-2005 19:56:10
It costs less money for a real three point made with quality welds and metal. From Hoxey Hitch or Saginaw Hitch. Both are in Michigan.
Missouri Boy
08-21-2005 19:13:13
What are you going to use for a hydraulic pump? I bought a good WD for about what a pump. valve, hose, and cylinder would cost.
RayP(MI)
08-21-2005 18:20:30
Look up yur tractor on worksaver.com website. They have a number of 3pts, and drawings of the various models. you should be able to pick up some ideas there.
Keith-OR
08-21-2005 10:59:45
third party image
Dick, here is a picture of the 3pt I built for my Allis C. It worked really great...Keith
Missouri Boy
08-21-2005 19:10:25
 Re: Homemade 3 point hitch? in reply to Keith-OR, 08-21-2005 10:59:45
The lift arms look like the ends are pretty far behind the tires. Most are a lot closer. It appears that you will not be able to lift much without the front end coming off the ground. First "C" I ever saw with a wide front. The wheels are strictly "C"
Keith-OR
08-21-2005 20:50:44
 Re: Homemade 3 point hitch? in reply to Missouri Boy, 08-21-2005 19:10:25
MO Boy was not built with the intend of lifting anything extremely heavy. Just a good usable 3pt for an old tractor that never had one. Good for blading drive. But don't think it will ever see much work anymore, a dealer bought it from me and now it sits in his show room..Fitting place after all the years it had set outside neglected and rusting away....Thanks ..Keith
Gary Walker
12-20-2005 12:38:04
 Re: Homemade 3 point hitch? in reply to Keith-OR, 08-21-2005 20:50:44
I am going ahead and adding a 3 point hitch to my C. Would like to have pics if you might have them available still. I'm adding the 3 point hitch to blade my drive and a lift to pick up a wood box with my chain saw and equipment for the woods. Nothing too heavy.
If you have pictures please email them to walkerg@gvsu.edu
Thank you.
Sincerely,
Gary Walker
Way Up Here
08-21-2005 16:26:15
Now tell us the truth, you manufacture 3-point hitches for a living right? Very nice, I mean VERY nice !!! True craftmanship !!!
Keith-OR
08-21-2005 20:37:12
 Re: Homemade 3 point hitch? in reply to Way Up Here, 08-21-2005 16:26:15
third party image
W.U.H., Nope just built that one for my Allis, I am a jack of all trades Master of one. Been building things that I need at the time all my life. You should see my over head crane that I use to split tactors, since I have to do everything alone. Seems every time I need help all my friends are busy. Here is a bucket that I made for a friend's Case VAC 14 . Thanks for the kinds words...Keith
old
08-21-2005 09:16:56
I made one for my Oliver 77, it works ok I haven't tried it with a plow but it works good with a disc, 3 point rake, etc. On a WC it shoud be easyer to make then on my Oliver. Drop me an e-mail if you want more info/picture
