Tractor Talk Discussion Forum
Wisconsin timing gear
diannashearer@yahoo.com
08-23-2005 20:48:04
Will a VH4D interchange with a VE4D?
fireman3
08-24-2005 20:12:58
 Re: Wisconsin timing gear in reply to diannashearer@yahoo.com, 08-23-2005 20:48:04
just a heads up if you have her torn all the way down. i would check the 4 oil jets to ensure they are not pluged. i rebuilt a vh4d 3 years ago and found all of the jets resticted.
08-28-2005 15:38:00
 Re: Wisconsin timing gear in reply to fireman3, 08-24-2005 20:12:58
Fireman 3,
Do you know how to pull adaptor off back of engine that mounts up to Universal connection between engine and hydrostat drive?
Glen in TX
08-23-2005 22:49:51
Mag gear or cam gear? I would say probably not as most things between them were different. Someone at small air cooled engine dealer should know more. www.wisconsinmotors.com www.planopower.com
08-24-2005 00:13:34
 Re: Wisconsin timing gear in reply to Glen in TX, 08-23-2005 22:49:51
The cam gear and crank gear numbers match, but the idler gear numbers match all but the last part. One is B-1 and the other is GC-27-B-2.
JT
08-24-2005 06:31:42
 Re: Wisconsin timing gear in reply to diannashearer@yahoo.com, 08-24-2005 00:13:34
Diannashearer,
Normally on Wisconsin parts, if the base part number is the same, the last number is an updated part. If they look the same and all the specs, seem to be the same, normally they will work. Jim
