Tractor Talk Discussion Forum
8N Oil psi
Roger Huffines
08-26-2005 12:32:22
I had my 8n overhauled but the oil pump was not replaced. now sometimes my oil pressure is like 20 psi & at other times it may get up to 50 psi. Any idea's?
BLW
08-31-2005 08:25:17
 Re: 8N Oil psi in reply to Roger Huffines, 08-26-2005 12:32:22
It is probably the pressure relief valve on the pump-- they get sticky and lost of times when the shop rebuilds the motor they do not clean it and check the spring- it is not a hard job but this will maybe solve your prob.
frankiee
08-26-2005 20:43:57
Link
Go to this site and scroll down to the questions..... .....
Q: "I changed my oil and now I have no oil pressure."
Q: "How much oil pressure should I have?"
May give you some ideas
IanC
08-26-2005 18:55:11
Whoever overhauled it probably didn't put in a new relief plunger and/or spring. Worn ones will have more than one flat spot and cause intermitant problems like you're having.
IanC
08-26-2005 18:49:22
Illinois Boy
08-26-2005 12:52:34
Oil pump... faulty gauge... clogged sensor line... bad sensor. Just thinking out loud!
