Tractor Talk Discussion Forum
exhaust manifold on F-12 Farmall
F-14
08-27-2005 18:31:14
hi
im wondering if a Farmall F-12 exhaust manifold will fit a F-14 Farmall any awnsers will help out thanks F-14
Fawteen
08-28-2005 03:40:45
 Re: exhaust manifold on F-12 Farmall in reply to F-14, 08-27-2005 18:31:14
Yes, it will fit. They are identical.
Kevin Bismark
08-27-2005 21:04:27
I have herd of folks doing it, had one that didn't have the same power after he did it, but I don't see how that could be, don't quote me but I think that the f-14 is the same block with a larger bore, I hope to get my hands on an old abandoned f-14 by the fall.
Kevin
RN
08-27-2005 22:02:14
 Re: exhaust manifold on F-12 Farmall in reply to Kevin Bismark, 08-27-2005 21:04:27
f14 block? f12 and f14 engine size the same-bore and stroke. Manifolds, posible compression diference- about the like same changes from Regular and F20 engines, same displacement with upgrade to carb, manifolds. C/Super C blocks had/can have bigger bore- 113 cubic inch increased to 123, can get up to 135 on latest sleeves/pistons with a bit of work.
