Tractor Talk Discussion Forum
3 PT hitch lower link point
53GoldenJubilee
08-29-2005 14:24:42
Hi guys,
On my 53 jubilee there are 2 studs or bolts the anchor the bottom links for the 3pt. The left side seems to be correct with no play in the stud but my right side anchor has lots of play and rotates freely , so freely that it cant be undone but it wont pull out and I cant take the right bottom link off the anchor. How is this supposed to be setup? Can anyone give me a diagram of inside the axle housing to show how this system works? thanks a bunch.
Coldiron
08-29-2005 17:17:14
 Re: 3 PT hitch lower link point in reply to 53GoldenJubilee, 08-29-2005 14:24:42
From what you describe it sounds like the lower link pin has loosened from inside. You will have to take the trumpet off and get her fixed. If you leave it as is you may end up with an egg shaped hole so sooner is better.
