Tractor Talk Discussion Forum
Re: Long 460 diesel three cylinder Fiat engine
Jim in NC
08-30-2005 03:48:54
Take the fuel line loose at the fuel pump, open valve, and see if you have a good, sustained flow of fuel. If you do, there should be no blockage in the tank. Then I would consider a new fuel pump. I replaced one on a friend's 360 about a year ago because it seemed to be running out of fuel often. He had changed filters and cleaned pump screen. These helped but did not cure the problem. The cost should be around $30. I have used Longs for almost 30 years and have replaced pumps 2 or 3 times. Good luck with your tractor.
