Tractor Talk Discussion Forum
OT: Truck question
Pawel
09-01-2005 19:30:13
Hi all, this is somewhat OT due to the fact that its about a truck but on topic due to what I may be using the truck for - hauling tractors :)
I have a F - 150 older model with 6 cyl in line gaser and 5 spd... only prob is I"d like to put a tach in it and Im not sure where to connect it to.
I looked in the F 150 book and it doesnt seem to have my syle of engine that straight 6 type.
Doers anyone have any ideas where the tach cable would hoook up?
The option of a tach or not came factory installed on the truck so there must be a connection port for the tach Somewhere on the block but I can"t seem to locate it.
Is there a possiblity that it would be a electronic tach sensor that would eliminate the need for a manual connection?
If any of you had any advice or expeience with this I would be grateful.
Thanks and God bless.
Pawel
*If you ate today thank a farmer*
Mopower
09-02-2005 07:11:07
 Re: OT: Truck question in reply to Pawel, 09-01-2005 19:30:13
I had a 1992 F150 with a beefed up suspension and engine. I found a 4000 RPM mini tach that hooked to the coil with an easy wiring diagram. I loved it. That engine doesn't run very fast...at leats with my automatic. 180,000 miles and never used a drop of oil. Running a Powerstroke now.
Redmud
09-01-2005 21:00:44
Pawel, if you don't have the tach yet, get an electronic tach and it will come with the info for to install it.
doogdoog
09-01-2005 20:24:40
Aloha, I would try looking around the distributor.
Mahalo,
doogdoog
twopop
09-01-2005 20:09:23
you can buy a tach at napa that connects to the coil.you set it to 4 6 or 8 cylinders.the coil firing reads the rpm's
Mikeky
09-02-2005 04:52:02
 Re: OT: Truck question in reply to twopop, 09-01-2005 20:09:23
The harness that attaches to the coil should have tach con marked on it. I think it is the green wire on the connector.
