Tractor Talk Discussion Forum
Farmall radiator
dmmoore
09-02-2005 07:22:53
Can a C Farmall radiator be interchanged with,say, an A,B,100,radiator?
Red Dave
09-02-2005 07:55:21
 Re: Farmall radiator in reply to dmmoore, 09-02-2005 07:22:53
Sometimes, yes. sometimes no. A C radiator likely can be interchanged with a Later A or B, like a '45, '46 or 47, but not an early one such as a '39 or '40. Difference is in the way the hood attaches to the radiator.
I think a 100 radiator is the taller one, like on a Super C, therefore it wouldn't be the same.
dmmoore
09-02-2005 08:01:47
 Re: Farmall radiator in reply to Red Dave, 09-02-2005 07:55:21
I think mine is a 1950 Super C. It has the shorter radiator than my 200. I"m told the early Super C"s came out like the regular C, with the exception of disc brakes and water pump.
Thanks for the information.
Red Dave
09-02-2005 08:46:55
 Re: Farmall radiator in reply to dmmoore, 09-02-2005 08:01:47
I don't think so. Super C didn't start until 1951.
If your serial number is 6 digits (100,000 & up), you have a Super C. If it is 5 digits or less, you have a C. Plain and simple.
A 200 is a Super C with slightly different sheet metal.
dmmoore
09-02-2005 09:18:22
 Re: Farmall radiator in reply to Red Dave, 09-02-2005 08:46:55
Thanks for the info. How/where do you find the serial number and how do you decipher the year and so on?
I based my guess on a letter that I kept finding in what looked to be dates,ex. 12 12 T. I find these stamped into the motor/trans,rear end. The I.D. tag is located on the right side of seat box with a number that does not make sense to me. Can you find the manufacture date and size of tractor using the above mentioned casting numbers?
Red Dave
09-02-2005 09:29:59
 Re: Farmall radiator in reply to dmmoore, 09-02-2005 09:18:22
The ID tag on the right-hand side of the box below the seat is the only place the chassis number is to be found.
It will have a "prefix" like "FC" followed by some numbers and sometimes a letter or two. The prefix is the model, the numbers are the serial number, and the letters (and sometimes numbers too) after the serial number are the suffix, which denotes certain options such as the clutch type or high altitude pistons or kerosene burner etc.
dmmoore
09-02-2005 09:42:44
 Re: Farmall radiator in reply to Red Dave, 09-02-2005 09:29:59
Thanks! I see if I can narrow the year down on my project.
Paul in Mich
09-02-2005 08:17:04
A radiator from an A, B, BN, AV or another C will work then....excluding of course 1939 and 1940 models which have dzeus fassteners, and super C and Super A1 which has the taller radiator.
