Tractor Talk Discussion Forum
4430
Jerry Bucki
09-04-2005 17:42:30
I have a JD 4430witha syncro trans that will not go in reverse or high range it choaks the engine off all low range forward gears work fine any insight on this??
twopop
09-05-2005 07:40:25
 Re: 4430 in reply to Jerry Bucki, 09-04-2005 17:42:30
your reverse gear is probably stuck to the shaft also.the gear has to be able to spin on the shaft so that the shaft splines and the drive teeth on the gear can line up and go into gear.the tractor will have to be split,the cab removed and the rockshaft housing taken off,in order to get the shaft out for repair.
twopop
09-05-2005 06:23:07
the low range gear on the top shaft has stuck to the shaft.the high range and low range gears spin on the shaft at differant rpm,s.so when you put the trans in high range,it is locked in two gears at the same time.usually this is caused bt towing the tractor without the trans being in tow position.if the tractor wasnt towed,possibly the trans hyd pump was not lubing the shaft as it should.
