Tractor Talk Discussion Forum
Argon co2 vs plain co2 gas
Way Up Here
09-05-2005 07:13:03
Looking at buying a mig welder, probably a Miller. Anyways, I've got to decide whether to go with the Argon/co2 mixture for shielding gas or just plain co2. The co2 is quite a bit cheaper for refilling bottles but I've been told that I would be happier with the mixture (although it's much more money). What are the advantages and disadvantages of each type of sheilding gas (other than cost)?
Duner Wi
09-05-2005 18:11:31
 Re: Argon co2 vs plain co2 gas in reply to Way Up Here, 09-05-2005 07:13:03
I purchased both gases and found out I generally use the CO2 mostly. I use my wire feed Linclon on thin metal.
moli
09-05-2005 16:24:14
you get a little better penetration with co2 but you also get more splatter..go with the mix its cheaper tha straight argon but not as cheap as straight co2...just get yourself a good nozzle dip and use it...steve
old dude
09-05-2005 10:35:11
Ag/CO2 aids penetration and provides a more stable arc 75%- 25% and higher mixes. Co2 will work for general applications if spatter is not an issue.
RJ-AZ
09-05-2005 08:42:09
If this is for home/farm shop welding you can do allright with the straight co2. The argon/co2 is pretty expensive for plain old welding especially if you are doing a big job.
knauffj
09-05-2005 08:06:29
The mix is supposed to be better for welding mild steel, so I've been told. Don't have any complaints, even when welding rusty metal.
farmweld
09-05-2005 07:48:54
 Re: Argon co2 vs plain co2 gas: HEY T-BONE in reply to Way Up Here, 09-05-2005 07:13:03
not sure one the advantages and disadvantages of the shielders, but do know from expirence that a lincoln electric mig welder is most likly of better quality. i had the oppertuntity to see a miller mig torn apart, and a good many of the bushings inside the machine are wood, an i just wasnt impressed with the inside quality.
how thick of material are you planning on welding? last i checked, thickest the manufacture reccomeded was 5/8 inch for any mig
farmweld
