Tractor Talk Discussion Forum
Lots of batteries
WiCraig
09-05-2005 15:51:30
Am looking to set up a charging station for 7 batteries for a low charge over the winter months using the same charger. Any ideas?? Thanks.
thejdman01
09-06-2005 14:29:20
 Re: Lots of batteries in reply to WiCraig, 09-05-2005 15:51:30
assuming the batteries are all the same voltages which they would have to be to use same charger just take some jumper wires connecting positive posts and negative posts. shouldnt need too big of a wire if your only using a truckle charger anyways.
Jon Holt
09-05-2005 18:20:54
Get a piece of plywood or other board. Get two metal strips and fasten it to the board. Get a trickle charger and make up some leads with large alligator clips on each end and set the batteries on a shelf or something off the ground.
msb
09-05-2005 16:44:24
Check out a "Battery-Minder" .They work good .
www.northerntool.com
msb
09-05-2005 16:44:17
