Tractor Talk Discussion Forum
Towing an Implement
Allan in NE
09-07-2005 15:50:51
Hey Guys,
I've got to tow an old Vibrashank 'bout 23 miles and it has a sloppy hitch yoke.
What's the plan again? I bommer that hitch back over against itself to hold it steady going down the road?
Thanks,
Allan
bubba 2
09-07-2005 20:24:31
 Re: Towing an Implement in reply to Allan in NE, 09-07-2005 15:50:51
Now tell us the truth Allen.Did you bomb it or boom it?? Or did you get bombed? LOL.
Must never have owned a John Deere KBA disk did you?They waddled like a duck if you didn't chain boom them.
Allan in NE
09-07-2005 18:34:09
Hey Thanks!!
We got 'er pulled home. That ol' sister is a little deceiving.
Pulls real easy, but like Paul says that darned tail will wag the dog if ya don't watch the speed. Tongue is balanced just about right, but the thing is sure heavier than I thought it would be.
How big of a mule does it take to tug one of these things anyway(18 footer)? 686 gonna do it, 'er not?
Anyways, all's well that ends well and we got out of the office fer a couple of hours. :>)
Thanks again,
Allan
caseyc
09-07-2005 19:45:38
 Re: Towing an Implement in reply to Allan in NE, 09-07-2005 18:34:09
hey allen,
the 686 might handle it. i also have a 18' vibra shank. my 706 will work with the wings up, put the wings down and it'll stop her cold. haven't had it on the 766 yet. the 766 plays with my disc(as you have seen). the 706 works on it. i'm betting the 966 will be a better match so you can go alittle faster and not be short on power 8>}
casey
Allan in NE
09-07-2005 19:53:09
 Re: Towing an Implement in reply to caseyc, 09-07-2005 19:45:38
Thanks Pard,
How do you control the depth? Is this one of those "cylinder, stopper, ringy" things? :>)
If they are anything like a rowcrop cultivator, they'll sink to the 'nads. Salesman told me to get it adjusted fer level and then run it 2 or 3 inches deep. Sound right?
I've never owned one before,
Allan
Leland
09-08-2005 20:10:51
 Re: Towing an Implement in reply to Allan in NE, 09-07-2005 19:53:09
Allan depth control depends on what kind of cylinder you have most newer ones have built in depth control or if it is older just put a set of sleves have fun and put it on your largest tractor and go but check every nut and bolt they can shake there selves abart .
wh
09-07-2005 17:32:19
sounds like a nice afternoon drive on one of them farmalls you have would be proper!!
Mike in MI
09-07-2005 16:27:42
Allen,
Take a log chain and hook one end to the yoke and the other end fasten it to the outside front beam on the Vibrashank an hook a chain binder in middle of the chain and bind it tight this will take the excess play out of the shank. Come alone will work also.
Good luck, Mike
paul
09-07-2005 16:00:09
I brought an 18' home 90 miles - that was exciting - and a 22' home about 15 miles. Problem is they have harrow bars added to the back, making them rear-heavy. This picks up on the pickup hitch.
That will make them unstable down the road. Probably 20 - 25 mph. Be _real_ careful when going down hill. Nothing really to do about that but take the harrow off, or flip it forward if you can. It will weave if the tounge is light.
If the tounge puts down pressure on the hitch, then pulling all side-slop out of the hitch with a come-along from the hitch pin to the left side of the frame of the machine will sure help.
Worst was a JD disk I brought home 10 miles. Too short wheel base, very sloppy hitch, rear heavy. 11 mph was ok, 13 was too much. What a long 10 miles on a state highway..... .
--->Paul
sawtooth
09-07-2005 18:54:55
 Re: Towing an Implement in reply to paul, 09-07-2005 16:00:09
Reading about a light or negative weight hitch made me wonder- if you're going a pretty good distance wouldn't it be worth it to chain some weights (wheel weights?) on the hitch to add tongue weight?
JMS/MN
09-08-2005 08:27:32
 Re: Towing an Implement in reply to sawtooth, 09-07-2005 18:54:55
If you have livestock you just stop by the feed store and get 500 lbs to put into the truck. Even horse feed works for that. Better than chaining extra weight on a machine tongue- no danger of falling off.
