Tractor Talk Discussion Forum
JD hydraulic
Randy Renfro
09-10-2005 09:17:22
I have a JD 1120 which started bursting hyd lines,ie main output from pump & power steering pressure side. After replacing those, now it is leaking around the o-ring on pump. I believe I have too much system pressure like the pressure relief valve is stuck.
What would be my next plan of attack!!!
Thanks
Randy
Tx Jim
09-10-2005 09:31:59
 Re: JD hydraulic in reply to Randy Renfro, 09-10-2005 09:17:22
Randy,you need a 3000 psi gauge to check stand-by pressure! 2250/2400 psi is allowable. I was sitting in sound-gard body on a 4430 that stroke-control malfunctioned and it split rockshaft housing. I'll never forget that day!!!!! Tx Jim
