Tractor Talk Discussion Forum
1800 oliver diesel
Dale Gray
09-10-2005 13:03:10
Hello, My 1800 oliver diesel gets fuel in the oil and also looses power. It will idle ok but won't run long at higher power settings. I think it may be a bad diaphram in the fuel pump. Any ideas ? And where can I get a new pump ? Thanks, Dale
Jeff Oliver
09-10-2005 14:40:53
 Re: 1800 oliver diesel in reply to Dale Gray, 09-10-2005 13:03:10
What sseries is yours? Does it have the Waukesha or the Perkins? Perkins has injectors on top and Wakeshau has them on the side. I literaly had this same problem a few months ago. ou can get a pump at the dealer but they are a little pricy. I tried several parts stores and no one could get one for a Waukesha ( I am assuming this is what you have ) However, before buying one take yours apart and check the diaphragm. Mine was still good and I wound up getting the injection pump rebuilt. There are some deals in the pump that might be bad and that may be all that needs changing ( not on mine of course, I don't have that luck ).
Check the tansfer pump first and if it is not torn or holes in it you are probably looking at the injector pump.
