Tractor Talk Discussion Forum
FORD HYD OIL WT ?
FDBYRD
09-11-2005 05:45:16
I HAVE A FORD 1801 IND.BACKHOE 1958-1960,IT HAS A FRONT MOUNT PUMP. I HAD A FEW SMALL LEAKS ON THE UNIT SO I STARTED ADDING 30WT MOTOR OIL TO THE HYD TO HELP SLOW THEM DOWN.SOON AFTERWARDS THE PUMP PUSHED OUT THE INPUT SHAFT SEAL. DID THE 30WT CAUSE THIS,OR WAS IT JUST TIME FOR IT TO GO?
YES
09-11-2005 14:17:18
 Re: FORD HYD OIL WT ? in reply to FDBYRD, 09-11-2005 05:45:16
IF IT WAS 30 WT HIGH DETERGENT IT WILL FOAM UP AND CAUSE PROBLEMS. DOUBT THAT AT THE PESSURE YOUR PUMP IS PUTTING OUT, THE 30WT WOULD SLOW THE LEAKAGE DOWN.
