Tractor Talk Discussion Forum
tire ballast
bebe
09-14-2005 03:37:03
How much water to put in rear tires to do most good? Have no weights...water only option for now!
buickanddeere
09-15-2005 01:45:07
 Re: tire ballast in reply to bebe, 09-14-2005 03:37:03
Depends? Do people need glasses? Drawbar loads, what type,three point hitch being used, loader, tire size, type, tread, soil etc. 2WD bias ply tires doing draft work at 3-5 mph? 115 to 145 lbs per pto HP with 65% of the tractor's weight on the rear wheels. You very well maybe bettwe off wihtout adding ballast. There is a habit out there.Grand Pappy added ballast, Pappy added ballast so I should add ballast too.
JMS/MN
09-14-2005 12:24:22
Tractor manuals tell you to fill the tire 3/4 full- not to have the valve at tdc, but below that. You need 1/4 of the space for proper cushion of air.
Keith-OR
09-14-2005 09:34:23
As John and Allan has said fill to almost full, be sure to put in antifreeze for your area. Here is a website on ballast chart and weight..HTH Keith
John A.
09-14-2005 04:29:57
Bebe, put the air valve at TDC when you rotate the tire and wheel. Then do as Allan said, All you ca get. At that point is when a tir is fully loaded. also you will want the small air pocket at the to to be able to check the tire pressure with a standard air gauge. if not then you will need one that will work on water. Also do not forget to use ssome sort of Anti-freeze protection.
Later,
John A.
Allan in NE
09-14-2005 03:50:16
Bebe,
Fill "em as full as you can get "em. If you don"t, that fluid tends to "slosh" around and gives you unwanted movement.
Allan
