Tractor Talk Discussion Forum
Oliver HG 42 serial numbers
freds
09-15-2005 12:09:21
A friend recently picked up another HG 42. One has a serial number 46 GA880 the other 42 GA 368. Can anyone help identify what these numbers signify? Thanks, Fred
J. Schwiebert
09-15-2005 16:01:17
 Re: Oliver HG 42 serial numbers in reply to freds, 09-15-2005 12:09:21
They are both 1949 models. Cletrac used a set up that varied a little but there is one or two numbers then two letters and then more digits. Look over on the left and check out the serial numbers under cletrac. But should have the Hercules IXA engines In early 1950 engines were changed to the IXB engines which has a larger bore by 1/8 inch. There were many other changes at this time. I would like to know what the engine numbers are. That number istamped toward thetop of the block on the left side. More questions?
freds
09-16-2005 16:24:05
 Re: Oliver HG 42 serial numbers in reply to J. Schwiebert, 09-15-2005 16:01:17
thank you for the reply, I have engine # for just one of the tractors IXK 32426568 008 (42ga368 tractor) When i go to my friends house next time i,ll get the other engine # ,probably have more questions then Thanks fred
