Tractor Talk Discussion Forum
Tractor Hydraulic Fluid
37 chief
09-16-2005 14:38:33
About 4 months ago I drained 10 gal of T.H.F. from my JD because it showed signs of water. I took it to the local oil dump sight. When I poured it out it looked like new oil again except for some water in the bottom. The oil is gone now. On my next oil change, could this oil be used in a oil bath air cleaner? After it sets for a few months or is it too thin. Stan in calif.
NEsota
09-16-2005 18:16:36
 Re: Tractor Hydraulic Fluid in reply to 37 chief, 09-16-2005 14:38:33
If you think that moisture is the only problem with your oil, you might freeze what you drained and then pour the oil off to make your decision on how to use it. If you're on the wrong side of the Mason-Dixon for the ambient to freeze it, then best get her permission before ya use the freezer.
