Tractor Talk Discussion Forum
loader for vac
scott vaughan
09-17-2005 06:53:39
I would like a or like to build a loader for my VAC. Can anyone help with a used one or plans to build one. Thank you , Scott Vaughan.
jon holt
09-18-2005 20:13:57
 Re: loader for vac in reply to scott vaughan, 09-17-2005 06:53:39
I am in the process of putting a loader on a VAI that came off of a VAC, but was originally on a Ford 8n. I believe it is a dearborn. It has a few things on it that need to be retrofitted, but it does fit. I can try here in a few days to get some pics of it and put it up on the photos or email you with them. My email is caseihno1@aol.com
Hal/WA
09-18-2005 11:54:32
If you have the narrow, 2 wheel tricycle front end, be careful. That front end is not the strongest. When I was a kid, we had a VAC. One time when I was plowing, the front wheels broke off the upright movable steering shaft. The wheels rode back under the oil pan and were almost to the transmission before I was able to stop the tractor. The front wheels and tires were still on the spindles, which were holding together, but the upright shaft had apparently crystalized and broke suddenly.
We were able to get a good used assembly and fixed the VAC fairly easily and cheaply, and used it for years afterwards. But there was no warning of the problem before the front wheels came off. Luckily I was plowing at a fairly slow speed and could get it stopped befor the front end dug in. It could have been real bad if I had been going fast down the road in high gear!
I would be real careful trying to use a loader with a tricycle VAC. Maybe my experience was unusual, but I don't think that front end is up to adding a lot of load to it, like a loader might do. I enjoyed the old VAC and have many good memories of the many times I used it. It was a very good tractor for our farm, except for that one dangerous incident. Good luck!
mj
09-17-2005 20:06:09
Check out the link.
