Tractor Talk Discussion Forum
8N 3 Pt hitch is very sick ? Low Power !
Robbo
09-17-2005 10:13:59
This is also posted at the 8N thread.
However, just in case other guys know the answer too....
I just got my first tractor recently
The 3 pt hitch will lift about 100lbs
That's it !????
Also,
It seems to operate in small jerky movements
I check the dipstick oil its within the marks.
Questions
What goes wrong?
how expensive $ to repair?
What oil is used?
Is this the same oil for the transmission?
Sat 17th at 1:15pm
Thanks You
Robb
Syracuse NY area
Jerry/MT
09-17-2005 10:22:06
 Re: 8N 3 Pt hitch is very sick ? Low Power ! in reply to Robbo, 09-17-2005 10:13:59
Could be a stuck valve, leaking piston rings, cracked cylinder, or a poorly adjusted control. Take the rt. side coverplate off and with the tractor running put the control lever in the lift position and look up at the cylinder to check for leaks. If you see a lot of fluid coming down from the cylinder your problem is either a leaking/worn set of rings or a cracked cylinder. Whatever you do, DO NOT PLACE YOUR HANDS OR ANYTHING ELSE INSIDE THE ACCESS HOLE WITH THE ENGINE RUNNING!
the control vlave resies on thepump and someone more knowledgeable than I will have to help you with that. Do you have a shop manual? If not you ought to get one to help you get started on solving these kind of problems.
Aussie Robb
09-17-2005 19:31:47
 Re: 8N 3 Pt hitch is very sick ? Low Power ! in reply to Jerry/MT, 09-17-2005 10:22:06
Jerry Thanks for the info.
I will check this out on Monday.
Do you know the price of the piston/rings or cyl.
or the cost of the control valve ???
Where do I find the best manual/s Best e'gards Robb
