Tractor Talk Discussion Forum
Guys from Mid west-NE
wayne2
09-18-2005 20:50:50
I just moved from western Wash. to Eastern,NE cornerCOLDER WINTERS, can a guy have to much insulation under the house and if he had 12x12x4ft blocks of styrofoam around should I shove those under to. Forum Subject I LIKE CASE DESERT TAN!!!
Coldiron
09-19-2005 07:34:44
 Re: Guys from Mid west-NE in reply to wayne2, 09-18-2005 20:50:50
Wayne2, Is that the NE corner of Wa state? If so we are almost neighbors. Priest River Id and it gets a bit nippy here when it gets down to minus 24. Around here we use the fiberglass batting so the underneath can breath. Lay 4 mil plastic over your crawl space to keep the moisture at a minumum and have good venting. The styrofoam would keep your moisture trapped but would work well in the garage against the door.
wayne2
09-19-2005 21:58:32
 Re: Guys from Mid west-NE in reply to Coldiron, 09-19-2005 07:34:44
Best pal from high school is there has Geralds 2 garage up on bit of a hill heading west out of town!! went thru mothers day to Eurika Mont. so what kind of cold iron ya got??? and what ya do with it??
Allan in NE
09-19-2005 06:35:40
Wayne,
Small potatoes. Forget the house and start worryin' 'bout the tax collector. That's where your problems lie. :>)
Allan
wayne2
09-19-2005 22:01:53
 Re: Guys from Mid west-NE in reply to Allan in NE, 09-19-2005 06:35:40
WHAT!! they should know I don't cotton to no revenures!!! I didn't say I painted the place LOL
Galen
09-19-2005 05:43:21
Where at in eastern NE? Yes you can over insulate and cause condensation and other problems. Also - over insulating can actually be COLDER than the proper amount. Insulation needs air pockets to work properly. A little extra (installed proper) won't hurt, but it's a fine line.
jfp
09-19-2005 05:22:15
I know this sounds crazy but check out a mobile home supply house and see what they use. You want something that will insulate and breathe at the same time. Lest the floors may get too much moisture and mold or rot or what ever could be a problem.
