Tractor Talk Discussion Forum
PTO hydraulic pump
Yooper-Al
09-19-2005 11:23:16
Need a pump for a 1 1/8", 6 spline shaft. 12 GPM or better, in working condition. The cheaper the better! Write a.zeutzius@prodigy.net Thanks!
Al
Yooper-Al
09-19-2005 12:16:47
 Oops, I meant 1 3/8 in reply to Yooper-Al, 09-19-2005 11:23:16
Oops, I meant 1 3/8"
Thanks
Mike M
09-19-2005 11:51:11
 Re: PTO hydraulic pump in reply to Yooper-Al, 09-19-2005 11:23:16
Your chances are going to be better looking for a 1 3/8" shaft and use an adapter to get it down to 1 1/8"
Yooper-Al
09-19-2005 15:25:04
 Re: PTO hydraulic pump in reply to Mike M, 09-19-2005 11:51:11
Thanks Mike, my screw up... I meant 1 3/8"
Al
paul
09-19-2005 15:45:31
 Re: PTO hydraulic pump in reply to Yooper-Al, 09-19-2005 15:25:04
You might want to consider the classified section - as it says in the upper right corner, discussion is prefered over ads in the discussion forums.
What do you need to run? Going to a backhoe, loader, or?
--->Paul
Yooper-Al
09-19-2005 17:35:12
 Re: PTO hydraulic pump in reply to paul, 09-19-2005 15:45:31
Thanks Paul. Just mounted a front loader on my old Massey Ferguson and need more capacity than the internal hydraulics can provive.
Al
paul
09-20-2005 08:44:43
 Re: PTO hydraulic pump in reply to Yooper-Al, 09-19-2005 17:35:12
Figured it was a hydraulic pump, tho as mentioned on the other forum, coulda been a water pump you were looking for too. I'll assume you are in the north of Michigan - helps to mention location when doing an ad. :)
--->Paul
