Tractor Talk Discussion Forum
hough HR loader
dave dobbe
09-20-2005 09:08:28
I need help with hercules six gas motor I can not get started. It just backfires through carb. The valves were ground and has not started since.Anyone know what gap should be between valve and lifter.Also need help with steering box for same loader. Thanks Dave
John in Ct
09-21-2005 12:32:25
 Re: hough HR loader in reply to dave dobbe, 09-20-2005 09:08:28
My manual says: " Valve tappet clearance-See instruction plate on engine". Sorry I couldn't be of more help. I will keep checking.
John in Ct
09-21-2005 12:37:25
 Re: hough HR loader in reply to John in Ct, 09-21-2005 12:32:25
I found tappets at least .007" intake, .010" exhaust. Warm engine, at idle, check and reset. I hope this helps.
wayne2
09-20-2005 20:22:25
I let one slip thru fingers for to-30 and back blade(stupid,stupid,stupid) it was rear wheel drive more iron then a tank, cylinders like a 4ft hemlock,and points setting in it off canter. wife killed that brain _art.(why am I married)oh ya the triangle
jfp
09-20-2005 19:11:03
Its been a long time since I have seen one of those. I can not help with the valve lash but if it backfires in the carb your timing is out way bad. Possible that the timing is set to fire on the intake stroke instead of TDC ? Most of the time I set it at TDC then fine tune it, if it still backfires, then it is likely 180 degrees out with the cam and crank. To set a valve on a rebuild remove the plugs and rotate the crank with a wrench until the valve sets flat (meaning seated inside the head). Then tighten down the rocker arm just snug because once it is running it will have to be readjusted. You may have to do each one seperatly to get it right before starting it. Maybe I'm wrong but I think the timing is the problem.
J. Schwiebert
09-20-2005 19:10:25
First of all what model Hercules? HAve you check compression? What did you set the valves at?
J. Schwiebert
09-20-2005 19:09:31
dave dobbe
09-21-2005 04:50:59
 Re: hough HR loader in reply to J. Schwiebert, 09-20-2005 19:09:31
You I do not know what Hercules motor it is I can not find any plates or numbers on this motor only reason I know it is Hercules is because of big letters on manifold.
