Tractor Talk Discussion Forum
90 Linclon front drive
jfp
09-20-2005 09:49:17
Any one ever had to deal with the air shocks going bad on these? My thought is the Thunderbird would interchange but I'm not sure about the hardware. We just want to fix it and sell it without a great expense. I know they have conversion kits but at 600 dollars it don't make it too feasible. V6 motor is too good to waste.
Jeff IA
09-20-2005 18:57:11
 Re: 90 Linclon front drive in reply to jfp , 09-20-2005 09:49:17
I had a 90 Town Car (rear wheel drive) with the rear air suspension. Replaced them with coil springs - $75 for the pair and about an hour's labor. If yours is front drive, it may be different. What model car?
I also quoted replacement parts - like new airbags, compressor, air lines, etc. But you still have an old system prone to leaks or problems in the area you didn't replace.
DRP
09-20-2005 14:07:23
My dad has a Linclon that the air shocks went bad on.He took struts off of a Tarus had to drill a extra bolt hole at the top but went on and worked just fine.Still going.
jfp
09-20-2005 18:49:32
 Re: 90 Linclon front drive in reply to DRP, 09-20-2005 14:07:23
Thanks neighbors. I knew something would interchange with a little modification.
Jack-Iowa
09-20-2005 13:01:50
You can get them at the stealership or sometimes they are on ebay.thunderbirds do not have them.
jfp
09-20-2005 13:14:57
 Re: 90 Linclon front drive in reply to Jack-Iowa, 09-20-2005 13:01:50
I didn't explain myself right again. What I mean is I do not want to put the air shock type back on it as it would just be more trouble later on . I trying to switch over to a regular shock. Thanks
dhermesc
09-20-2005 14:00:49
 Re: 90 Linclon front drive in reply to jfp, 09-20-2005 13:14:57
The ones off a T-bird will not work.
