Tractor Talk Discussion Forum
8n
8nbeginner
09-24-2005 17:39:59
my brothers 8n runs great for a little while and then dies. after resting for 10-15 minutes it will start and run again for a bit then dies again. any suggestions?
RAB
09-25-2005 02:22:26
 Re: 8n in reply to 8nbeginner, 09-24-2005 17:39:59
So now you have the alternative diagnoses, find out! Check spark quality, or existence, when engine dies - no spark = ignition problem.
Drain carburettor and watch fuel flow - must be full flow for at least a minute aftercarb is MT. Reduced or failing flow = fuel problem.
You could also try starting engine with choke or starting fluid for more info, check voltages at coil to see if it is ignition switch.
Hope this helps. Regards, RAB
Coldiron
09-24-2005 20:15:27
Beginner, When you say runs for a little while you need to be more specific on the time frame since different run times give a different diagnosis from electrical to fuel. If you have a time we might be able to pin point your problem. Hope this helps.
8nbeginner
09-25-2005 08:24:11
 Re: 8n in reply to Coldiron, 09-24-2005 20:15:27
the tractor will run for about 25-40 minutes. with either bushhog or disc then dies. after sitting ile for 10-20 minutes will start and run and then follow the same pattern. thanks for your help.
Paul Shuler
09-24-2005 18:08:39
Could be a bad coil. Had one do me that way on a Farmall C. Dad blasted coil anyway.
Nebraska Cowman
09-24-2005 17:45:18
it is not getting fuel
Adam Zich
09-24-2005 20:05:39
 Re: 8n in reply to Nebraska Cowman, 09-24-2005 17:45:18
I think it may be the distributor. The old front mount dist has a tar like substance in it used as an insulator that can heat up and melt. When you shut it down and let it cool the insulator hardens and should operate properly again. Check your temp gauge when it's running and see what it says. Just my thoughts.
-Adam Zich
steveormary
09-24-2005 19:36:34
Could be either one. Bad coil or dirty fuel lines. Had a Farmall 300 die in me every so often. Got to giving it the old stare down and it said its coil was bad. Replaced coil. no problems after that.
steveormary
