Tractor Talk Discussion Forum
Hyd.Lubrication
Bender
09-26-2005 04:09:39
Just got this F-1700 ford. It needs a lot of work. I am going through all the lubes. The manual calls for M2C-134A. hyd. fluid. Is there something speical about this or will any hyd.fluid work. What kind should I use. I will probly get it form TSC.
Thanks
Jon Hagen
09-26-2005 16:08:59
 Re: Hyd.Lubrication in reply to Bender, 09-26-2005 04:09:39
That Ford spec crosses over to an extreme pressure hy tran fluid ,same spec as the old IH B-6. DO NOT use a standard hydraulic oil as the additives are not correct for your application. Check the container of the fluid you intend to use and see if it lists the Ford or IH spec I listed.
