Tractor Talk Discussion Forum
O/T Stock Wells
Allan in NE
09-27-2005 10:33:12
Hi Guys,
Sounds like there is a load of livestock on the way so I spent the last two days getting the water works going.
Better go fetch some goldfish, I suppose. :>)
Allan
third party image
third party image
Rauville
09-27-2005 19:24:50
 Re: O/T Stock Wells in reply to Allan in NE, 09-27-2005 10:33:12
Well, you're pretty darn lucky to have that system working. Our lil' old farm has been without electrical power since last October. Seemed that during a new highway project, the underground service got cut...and then covered up with 25' of fill and a new 4 lane. Looks like I'll have to go out with my tiling spade and friction tape.
Looking at your place makes me kinda of envious.
BigMarv1085
09-27-2005 18:06:34
Hey Allen, how do you pump water to your tanks, windmill, solar, or electricity.
Allan in NE
09-27-2005 21:01:12
 Re: O/T Stock Wells in reply to BigMarv1085, 09-27-2005 18:06:34
Hi Marv,
This west pump is out in the pasture and is on an electric pump jack.
We just sank a digital variable speed submersible in at the yard/barn. Just got that one going today and it's still pumping a bit of sand.
Allan
Tony C.
09-28-2005 09:37:12
 Re: O/T Stock Wells in reply to Allan in NE, 09-27-2005 21:01:12
Tell us a little about the variable speed sumersible. Does it us a VFD controller? What is the HP and how much do you figure the variable speed feature added to the cost? What is the make of the controller?
I have an 8" well that is about 35' to water and the well is 70' deep. It has a line-shaft turbine in it and a right angle gearhead powered by a gasoline engine. We only use it a few months in the summer. I have toyed with the idea of removing the turbine and replacing it with a 6" 3-phase electric submersible, maybe 12-15hp, dropped in the same casing with a VFD controller. It is located 1000' from the 3-phase power source.
Island A
09-27-2005 16:34:57
Do you put goldfish in there to cut down on miskeeters or eat algae or what?
Dave
Allan in NE
09-27-2005 16:57:57
 Re: O/T Stock Wells in reply to Island A, 09-27-2005 16:34:57
Hi Dave,
They help keep down the algae. No skeeters out here to speak of; too derned dry.
Allan
Glen in TX
09-27-2005 17:12:36
 Re: O/T Stock Wells in reply to Allan in NE, 09-27-2005 16:57:57
If you get enough of them goldies the ice will be thinner in those tanks in winter too :)
landlord7012
09-27-2005 10:52:05
simple pleasures of life - watching those little goldies grow, and they make great tank cleaners too! Talk about surfa and turf in the tumble weeds!! Sounds like it"s all coming together for you.
Good luck and sound decision making,
landlord7012
Mike M
09-27-2005 10:35:14
Does it always look that dry out there ????
Allan in NE
09-27-2005 14:26:01
 Re: O/T Stock Wells in reply to Mike M, 09-27-2005 10:35:14
Hi Mike,
Ususally things are pretty green thru the 4th of July. From there on tho, things just burn up due to the lack of moisture.
Consequently, the whole area has adapted with cool, short season grasses which have all gone to seed by now.
Just had some boys out setting a new well and in their trenching and so forth, they never did hit any moisture.
It is just a dry country. :>(
Allan
dhermesc
09-27-2005 11:06:30
Naw, usually it looks really dry this time of year.
Illinois Boy
09-27-2005 11:20:08
 Re: O/T Stock Wells in reply to dhermesc, 09-27-2005 11:06:30
Allan,
In my neck-o-the-woods we"d call those hot tubs!!
Fill "em and let "em soak up some rays for few hours...
Looks good - now all you need is something that goes "moo"...
Harley
09-27-2005 14:27:31
 Re: O/T Stock Wells in reply to Illinois Boy, 09-27-2005 11:20:08
Got a load of them little heifers on the way huh? Whataya gonna do this winter when there is 2 ft of snow on the ground and the temp. is down there around 8 below? Don't look like there is nothing between you and the North Pole but maybe three strands of barbed wire. Good luck. Harley
joe e-tx
09-27-2005 18:34:49
 Re: O/T Stock Wells in reply to Harley, 09-27-2005 14:27:31
well harley as i said early this year large BBQ at allens.hahaha .allen just keep them from north wind and keep them fead.best of luck rasin cattle up there.just the thought of it makes me cold (thank you).it will pay off .
joe
steveormary
09-28-2005 10:09:45
 Re: O/T Stock Wells in reply to joe e-tx, 09-27-2005 18:34:49
Allan;
Over the top of the first tank there,it looks like an oil well rig out in the field there. Is that right??!!
steveormary
Allan in NE
09-29-2005 01:40:39
 Re: O/T Stock Wells in reply to steveormary, 09-28-2005 10:09:45
Hi Steve,
No, that is just a corner post/brace on the fence.
Allan
