Tractor Talk Discussion Forum
HD 3 Allis Chalmers
joseph moore
09-28-2005 08:34:33
I cannot find the procedure for separating the track...new bolts installed in the sprocket drive wheel after improper bolts sheared off...no mechanics in the area to service..all information will be thankful..
hector gemme
09-28-2005 16:59:13
 Re: HD 3 Allis Chalmers in reply to joseph moore, 09-28-2005 08:34:33
HI The master pine should have a small hole in center and the master boushing is less of the others and you should see the pine betweent the two links.good luck . HECTOR
joe moore
10-04-2005 16:56:43
 Re: HD 3 Allis Chalmers in reply to hector gemme, 09-28-2005 16:59:13
Hector I found the pin!!!! thanks..Intend to soak with rust buster and use torches to get it out with punch and sledge hammer..a little heat will expand the links...I could not answer sooner as on the 29th a storm blew trees down on my wires...tel..comp and house current..no phone service yet..was a real fun time replacing electric service..no water lights etc..as I am in the farm area..Do u still own a HD 3?? mine diesel...take care and thanks again...
hector gemme
10-05-2005 03:28:04
 Re: HD 3 Allis Chalmers in reply to joe moore, 10-04-2005 16:56:43
HI I am happy for you ,me I am old buldozer driver and am on pension and some time buy a dozer and dismantle for parts and have h3 final drive,stering cluch,transmission.GOOD LUCK .HECTOR
hector gemme
09-28-2005 09:55:56
HI You should found a different pine in the chaine and that the one you have to take it out and the chaine gone separate.HECTOR
joseph moore
09-28-2005 15:25:06
 Re: HD 3 Allis Chalmers in reply to hector gemme, 09-28-2005 09:55:56
To Hector Gemme that is my problem, they are all exactly alike in appearance..with no locking in mechanical device just straight thru pins..if I had a manual it would identify the pin...I was thinking someone out there had one..and could email me a copy...is there anyway of identifying the pin???? I appreciate your response...
