Tractor Talk Discussion Forum
Loud Cab
Green Giant
09-29-2005 07:32:22
I was wondering if anybody round here would have any suggestions on how to quiet down the interior of the cab on my 1170 Case. Im getting sick of ear plugs. Thanks :D
GREEN GIANT!
W.P. Wood
09-29-2005 14:46:09
 Re: Loud Cab in reply to Green Giant, 09-29-2005 07:32:22
That's easy... Remove the cab!
Allan in NE
09-29-2005 16:39:22
 Re: Loud Cab in reply to W.P. Wood, 09-29-2005 14:46:09
I agree,
Get that noisey derned thing off of there!
Least, that's what I did. Never could stand those gizmos! :>)
Allan
third party image
third party image
Glen in TX
09-29-2005 22:03:42
 Re: Loud Cab in reply to Allan in NE, 09-29-2005 16:39:22
Yep, It's going to be nice and breezy when you're feeding them heifers in that 3 ft. snow :)
Wrench twister
09-29-2005 13:50:47
We have cured several cabs of noise. Removed all panels and coverings and sprayed foam then reinstalled panels. Drilled small holes in cab supports and filled all posts with foam. Foamed the underside of all floor plates. applied foam over all dash panels that could be foamed and applied nagahyde to cover them. You have to be creative there. Packed insulation material in all behind dash spaces and control towers. Sound will find its way in through the smallest of gaps.
The foaming also made the A/C systems work better.
Glen in TX
09-29-2005 11:51:46
Harold Electric like Tim said. Ask them for samples of the sound deadening materials. Also couple other places I've seen the mats and material. Shoups www.shoupparts.com and K&M www.tractorseats.com You find some more in farm magazines or a search.
N. TX Tim
09-29-2005 11:23:28
Harold Electric Co. out of Washington state sells a lot of Ag related products to include Fehr Cab Interior kits. Yours would run you $244.35. There website is>Link
This>Link most likely includes the insulated materiel to cover both fenders and the floor under/around your seat.
I purchased an air conditioner kit as well as a cab interior kit for my Case 1394 when I was redoing it...and I was real satisfied with the customer service and quality of products. When ordering, make sure to tell them what transmission/shifter setup you have as this may make a difference in the kit.
Good luck
Tim
IA Roy
09-29-2005 09:41:00
Check to see that all the sound deadening insulation is in place. Check to see that the windows and door(s) are closing. Are there rubber isolators (mounts) under the cab and are they worn out? When dad bought his 1973 1070 it was the quietest tractor on the market as I recall.
sammy the RED
09-29-2005 08:10:23
Turn the radio down a little ! ;o]
Green Giant
09-29-2005 10:02:15
 Re: Loud Cab in reply to sammy the RED, 09-29-2005 08:10:23
I was thinking about covering the whole interior with old used carpet, i was wondering if this would help deaden the sound a lil bit. The only insulation that i know of is in the roof.
Illinois Boy
09-29-2005 10:12:06
 Re: Loud Cab in reply to Green Giant, 09-29-2005 10:02:15
There's some company that advertises in one of the magazines I get that sells cab replacement interiors. I'll try to locate the name and contact info and reply to your post.
