Tractor Talk Discussion Forum
OT: Tracing an electrical line
wirehair
10-03-2005 04:54:19
Folks,
I need your advice on solving an electrical problem. I have an outside GFCI outlet that quit working on me. I was going to move it, so I pulled the line and traced it all the way up the wall the header. At that point it goes across the ceiling.
This is in the mobile home. Last time I had a similar problem the breaker was getting tripped and I found a nail through the wire. No breakers are getting tripped this time and everything else electrical works.
Is there a device that will let me connect to one end of the line and "buzz" it so that I can tell where it runs inside the wall. I already had to ruin a bunch of new drywall and would like to minimize further damage.
Any advice will be sincerely appreciated.
wirehair
Hermit
10-03-2005 17:18:06
 Re: OT: Tracing an electrical line in reply to wirehair, 10-03-2005 04:54:19
Since you're going to move the outlet, can you cap off the old wire and find another circuit to tie the new outlet to? May save tearing up too many walls.
Steve_ne
10-03-2005 07:29:13
It's called a fox and Hound. Creates a tracer tone on the wire. Cost is $45.00
http://www.lashen.com/vendors/triplett/fox_hound.asp
Martini
10-03-2005 07:10:58
Yes, there is an electrical tester which signals
a live conductor. Probably expensive to purchase.
I would think it might be cheaper to find a local
electrician and have him check it out. Call an
electrical supply shop and find out what the price
range is. Sooner or later Home Depot will get them
just like the laser level craze but don't think
they have landed there yet.
John T
10-03-2005 07:03:27
I think Ive seen a non contact electrical test device at some home or elecrical supply house a while back that lit up when in the proximity of AC voltage, it must detect the electromagnetic field. So long as the feeder were hot out of the panel such a device might locate it if close enough to the walls or ceiling etc.
If you know what circuit that receptacle is on fed from you breaker box you could disconnect it there and ohm out the conductors to see if any wires are showing high (or low even) resistance continuity to other conductors. Even a high resistance short should cause the GFCI to trip out as I think they drop out at something like only 5 milliamps of current imbalance between the hot and neutral. However, the GFCI should also drop out even if there were no hot to neutral shorts discussed above but a short to the trailers metal frame as the result would still be an imbalance in the hot and neutral current flows.
I would ohm out the conductors as thats cheap n easy (but even if they pass there may still be a short elsewhere) and then purchase one of those AC Voltage detectors if you need to locate where the wire is.
Have you checked the GFCI elsewhere to be sure its okay and dont trip out any old place????? ???
John T, retired electrical engineer
dr.sportster
10-03-2005 08:48:25
 Re: OT: Tracing an electrical line in reply to John T, 10-03-2005 07:03:27
John,When a gfi is a receptacle the line feeding it is not gfi protected if thats what you are saying.A temporary gfi box on a job site is still fed off a normal breaker and that line is not gfi protected[like when the backhoe runs it over].Also a gfi is not overcurrent protection in any way.In this case the line is not on the gfi protection.
John T
10-03-2005 13:06:27
 Re: OT: Tracing an electrical line in reply to dr.sportster, 10-03-2005 08:48:25
dr. Thanks for the good feedback to which I agree. They make GFI "Receptacles" which would protect any loads or lines connected to and/or wired "downstream" of the unit and they also make GFI "Circuit Breakers" which would protect the feeder PLUS any downstream loads. As I understand them there's a torroidal coil through which BOTH the Line and Neutral pass. If the curents the same in BOTH they cancel each other out and no voltage is induced in the coil which can trigger the relay to open. However, if theres an imbalance cuz some of the current flowing to the load from the Line IS NOT ALL BEING RETURNED VIA THE NEUTRAL that means some portion of it it may be leaking off to ground or the equipment user etc. OUCH !!!!! !!!!!
Therefore I agree with your statements and appreciate someone actually reads these posts n thinks about them plus takes the time n cares enough to reply. If the posters feeder wires (to that GFI receptacle) had a fault it may or may not be sufficient to clear his protective device and wouldnt necessarily cause his GFI "Receptacle" to trip out as it wouldnt see the unbalanced flow upstream of it HOWEVER if he had a GFI "Circuit Breaker" feeding n protecting that feeder wire, it would.
I never consider a GFI "Receptacle" as an overcurrent protrctive safety device, only as protection if the line current flowing out of it isnt balanced by the returned Neutral current. The GFO "Circuit Breaker" however serevs as BOTH overcurrrent protection PLUS GFI.
I love this Sparky chit chat even if we bore others lol
Thanks again, John T retired engineer
dr.sportster
10-03-2005 13:25:37
 Re: OT: Tracing an electrical line in reply to John T, 10-03-2005 13:06:27
Since the end of the line where the gfi was removed is dead it does make this a troubleshooting problem.What needs to be done is to safely cap off the point of damage or the last splice its fed from.I think the tracer may be difficult to get around here.The only other thing I could think of is to backfeed the end of the wire and try a tick tracer but then you may risk sparks in the wall at the nail damaged spot.These electrical questions are tricky.You want to be helpful yet not cause further damage.I was out on the tractor before plowing woodchips still thinking about this problem.No brilliant revelations came to me so far.
wirehair
10-03-2005 07:25:41
I have a couple GFCIs in the bathroom that work fine.
There is no power on that line. I removed the GFCI and pulled the wire inside (it was outside surface mount). If I know which breaker it was on I would just re-route everything else that is on that breaker.
I need to trace the wire to find the breaker.
wirehair
NEsota
10-03-2005 06:42:54
Your question is reasonable one. There must others on this forem besides you and I who will benefit from serious ansewers to it. Someone must know and will come through.
dr.sportster
10-03-2005 06:00:05
There is a guy over on tool talk pretending to be you.He even asked the same question.
wirehair
10-03-2005 06:03:12
 Re: OT: Tracing an electrical line in reply to dr.sportster, 10-03-2005 06:00:05
I put the question on both forums. Thought I'd have a better chance to get an answer.
Hate the thought of burning the place down with electrical fire.
wirehair
wayne2
10-03-2005 06:03:04
Funny fellow!
