Tractor Talk Discussion Forum
O.T. Gear oil??????
SJ
10-03-2005 08:35:31
Friend of mine gave me a coupla qts of gear oil he found somewhere,Valvoline 85-140.My question is,whats this 140 about,never seen that high a number on multi viscosity.Every thing on my place takes 80-90,old and new equipment.
Thanks Stan
hay
10-03-2005 10:30:11
 Re: O.T. Gear oil?????? in reply to SJ, 10-03-2005 08:35:31
like was said, not real common anymore. i have some and use it for occasional leaky gearboxs when i don't have time to replace the seals.
JMS/MN
10-03-2005 08:50:07
Not uncommon in farm stores here- older tractors and machines used 140 weight in some gearboxes.
Illinois Boy
10-03-2005 12:51:54
 Re: O.T. Gear oil?????? in reply to JMS/MN, 10-03-2005 08:50:07
Yep - it's not uncommon here either...
JMS/MN
10-03-2005 13:49:50
 Re: O.T. Gear oil?????? in reply to Illinois Boy, 10-03-2005 12:51:54
I'd like to find some straight 140 again for some special project..... goofy parade tractor in need of especially good seal quality..... ..
NC Wayne
10-03-2005 20:46:30
 Re: O.T. Gear oil?????? in reply to JMS/MN, 10-03-2005 13:49:50
If you need something heavy to keep in where you've got a bad seal try some semifluid grease. it's pretty much akin to gear lube and grease mixed. It flows pretty good so it won't go to the outside of a gearbox like plain grease would but it's thick enough you can't pour it through a funnel. I recently got a 5 gallon bucket from Lubrication Engineers to put in the rotation gearboxes on a customers rock drills, hopefully to lengthen what's now about a year life expectancy on a $2000+ set of bearings. Like I said I know LE carries it but if you check around I'm sure some others do too.
Joe (Wa)
10-03-2005 17:13:39
Napa in my area sells StaLube brand 140 wt in qts. They have to order gal size tho.
Joe
Illinois Boy
10-04-2005 08:00:31
 Re: O.T. Gear oil?????? in reply to Joe (Wa), 10-03-2005 17:13:39
Get it online from Rural King in 2 gal containers.
About 12 bucks.
www.ruralking.com
JMS/MN
10-03-2005 18:17:16
Thanks to you and riverbend for the info. When the parade special is done I'll post some pix. Back home we used 140 in the finals/diff on the WC. Hard to find the straight stuff the last 10 years.
Joe (Wa)
10-03-2005 20:06:28
 Re: O.T. Gear oil?????? in reply to JMS/MN, 10-03-2005 18:17:16
Here is gal size info for Napa to order if need be.
Sta-Lube
SAE 140
API/GL4
P/n SL24238
Local stores only carry 1 or 2 qt containers. I don't have any qt size left but will get the p/n if you need it.
Joe
riverbend
10-03-2005 16:25:12
Simplicty has a 'Special Worm Gear Oil', their pn 118065. It is 140 wt. Hope that you don't need much.
