Tractor Talk Discussion Forum
ot 220 Bayou ATV
dr.sportster
10-03-2005 09:33:07
Anyone have the valve lash specs for the 220 Bayou.The owners manual gives you everything but this.Tells you to go to the dealer which means buy your own sevice manual.Trying to avoid buying manual for these specs.
Hoosier JD
10-03-2005 18:16:54
 Re: ot 220 Bayou ATV in reply to dr.sportster, 10-03-2005 09:33:07
Dr. Sportster,
I haven't adjusted mine yet, but here is what the manual says:
A. Remove the front fender, valve caps, timing inspection plug, recoil starter (to turn the crankshaft).
B. Turn the crankshaft counterclockwise, until the "T" mark on the magneto flywheel align with the pointer.
C. Measure the clearance of each valve between the end of the valve stem and the adjusting screw on the rocker arm with a thickness gauge.
*If the valve clearance is not correct, continue with the following procedure.
D. Loosen the locknut and turn the adjusting screw until the clearance is correct.
E. Hold the adjucting screw from turning and tighten the locknut to the specified torque (104 inch-pounds). Valve Clearance: Inlet 0.15mm - 0.20mm Exhaust 0.18mm - 0.23mm
Check the valve clearance only when engine is cold
or cool to touch.
Dr., as I stated before, I just did get the manual and have never adjusted mine (93 model). But this is from the manual verbatim. Good luck,
Mike.
dr.sportster
10-04-2005 05:33:29
 Re: ot 220 Bayou ATV in reply to Hoosier JD, 10-03-2005 18:16:54
Thank you.
