Tractor Talk Discussion Forum
positive or negative ground
Batman
10-07-2005 18:05:17
I have an 8n with a 6 cyl Funk Conversion. It was converted to 12 v before I got it. Now it has a negative ground. Is that normal? I thought about returning it to positive ground, but I am not sure if that is wise or even possible. I'm just a rookie. Any suggestions?
Dell (WA)
10-07-2005 19:38:10
 Re: positive or negative ground in reply to Batman, 10-07-2005 18:05:17
Batman..... ...12v alternators typically used in 12v conversions DEMAND NEGATIVE ground. Its a technical thing with solid state voltage regulator and diode rectifiers. Iff'n it ain't broke, don't fixxitt.
But to answer your other part of the question, yes both the OEM 4-cylinder engine and the flathead 6-cylinder engine used in the Funk conversion were 6-volt positive ground..... ...Dell, a 12v advocate for the right reasons
Van in AR
10-07-2005 20:57:48
 Re: positive or negative ground in reply to Dell (WA), 10-07-2005 19:38:10
Didn"t see where he said it had a alternator or not, if a generator, very easy to go either way.
Van
Batman
10-09-2005 17:03:13
 Re: positive or negative ground in reply to Van in AR, 10-07-2005 20:57:48
The 12v conversion uses a generator instead of an alternator.
Robin
Dell (WA)
10-08-2005 09:11:40
Van..... ..its true mechanical voltage regulators and old fashioned "stealth" 12v gennys don't care, positive or negative ground, as long as you correctly "polarize" to match the battery ground.
Howsomevers; unless the 12v converter was an "originallity-nut" where looks is everything, its a 99% probablility that the 12v conversion used the cheap and commonly available Delco 10-SI alternator that DEMANDS negative ground for solid state technical reasons. Remember Haakims Razor..... ...Dell
wayne2
10-07-2005 20:29:11
Dell, noticed the WA Where? I left Lk. Stevens 2 months age for n. of Colville-more sunshine-less traffic etc. I like Case desert tan!!! Wayne
Dell (WA)
10-08-2005 09:17:42
 Re: positive or negative ground in reply to wayne2, 10-07-2005 20:29:11
Wayne..... ..I live on my RockyRidge SheepStation at the foot of 14k Mt Rainier on the border of Ft. Lewis Army Post. 15 awesome acres of starvation grass where I raise sheep to train my Australian Shepherds to compete in herding trials against Border Collies..... ....Dell, ret Boeing Flt Test Engr
wayne2
10-08-2005 14:49:23
 Re: positive or negative ground in reply to Dell (WA), 10-08-2005 09:17:42
Dell, Spent 2 wonderful months Ft. Lewis (67)late then a couple more (68) at Madigan wasn't as brushy as up north in rain belt. LOL You should be enjoying yourself no folks that high up!! same where's i at not many less than 20 ccres for miles. Ret. Chiro-loggeer-trk driv-roof loader-tractor Mech. and ain't much good at raising kids though I tried. LOL Wayne
sammy the RED
10-07-2005 18:10:13
If it aint broke, leave it.
RayP(MI)
10-07-2005 18:21:23
 Re: positive or negative ground in reply to sammy the RED, 10-07-2005 18:10:13
Negative ground is to your advantage, as probably most of the other things in your stable are too - (Especially when booster cableing, etc.) Like Sammy says, leave it alone.
Pitch
10-07-2005 18:17:57
It was originally positive ground. Since it has been converted to 12v I am assuming with an alternator (as opposed to a 12v generator) you must run negative ground.
