Tractor Talk Discussion Forum
Scrap manure spreader as utility trailer?
Rod in Smiths F
10-07-2005 21:13:01
At the scrap yard today I saw a manure spreader someone had turned in. It has good tires and what appears to be strong tin, though the wooden floor is shot and one of the chains underneath has parted. The PTO shaft is intact.
If the beaters were removed and the sides braced, would it self-unload by PTO action to any extent when loaded with firewood or gravel?
Do many of you use spreaders for firewood, or are there better tractor trailers available for bush work nowadays?
What would be a reasonable price for this "beater" if it has been scrapped?
Bret4207
10-10-2005 12:14:35
 Re: Scrap manure spreader as utility trailer? in reply to Rod in Smiths Falls, ON, , 10-07-2005 21:13:01
Rod- If your spreader has a good chain and smooth sides and floor and you don"t heap the fire wood above the sides it would probably work. The problem is overloading, like I did, and the wood cathing on a side support or bolt head or other box part.
JDB
10-10-2005 10:28:13
Dad used an old one without the beaters all the time for hauling dirt, tree limbs, ect. Takes a while to unload because the apron chain is slow. Also, watch that it doesn't hit on a piece of firewood on the the way down around the back sprockets.
Leroy
10-09-2005 23:02:16
On some spreaders the beaters were powered by the PTO while the web was still powered by the ground wheels, if this is the case with this spreader then taking the beaters off you might as well take off the PTO shaft
Galen
10-08-2005 06:09:16
My neighbor uses his to haul firewood. He cuts 15 cord a year (sells to convienience stores). Most of it goes through the spreader at some point. He has also hauled gravel. His does have a metal floor.
Bret4207
10-08-2005 05:52:49
Tried it, broke the chain. New chain was around $300.00. T-bar chain.
10-08-2005 15:43:33
 Re: Scrap manure spreader as utility trailer? in reply to Bret4207, 10-08-2005 05:52:49
A dump trailer has to be quite high in order to have the clearance to dump. This makes it awkward to load with firewood, I would think. A conveyor system would need less effective height in order to function.
What if I replaced the t-bars with some sort of conveyor belt? They market belts for the back of pickup trucks. Probably expensive.
Is there any simple way to put a cylinder onto a spreader and make it dump?
RustyFarmall
10-08-2005 04:53:00
Had a neighbor that did that, it worked very good for firewood. Questionable with gravel, don't think it would haul enough gravel at a time to make it worth your trip to the quarry.
sawtooth
10-08-2005 04:28:40
I think it would work with firewood but you'd have to be careful because the apron would tend to catch on big pieces after they're off and tear something up. I think gravel would have it's own problem- especially if you loaded a lot. It would also get into the chain and eat it up.
Mike Van
10-08-2005 01:25:36
You could probably use it to unload sawdust, etc. but i'm not sure about something as heavy & hard to move as firewood. The pintle chain isn't that strong, this ones probably had years of acid working on it. The pto shaft is worth 100.00 if it's intact. Be good for moving long stuff - lumber, fence posts, you wouldn't have to reach & lift up over the sides.
PeteNY
10-07-2005 23:45:14
I'd pay $100...I'd love to find one to make look like a spreadr, but with benches for the family for parades
RN
10-07-2005 22:58:22
Price? Good tires? One to 2x scrap weight value to start, keep on good terms with salvage yard, save them labor to clean and crush. Iron is $70.00 a ton now? Use as tractor trailor, low speed (30-45mph) behind truck utility hauler.
sawtooth
10-08-2005 06:05:53
 Re: Scrap manure spreader as utility trailer? in reply to RN, 10-07-2005 22:58:22
This brings to mind a thought I've had. I've already been at the scrap yard and saw people bring things I've thought a little above "scrap". For instance an old garden tractor with perfectly good wheels and tires. If you ask the yard about the wheels they want a pretty hefty price. Seems like people would advertise things (in some businesses you can post ads for free) like the old spreader before just dumping it at the yard for bottom dollar.
