Tractor Talk Discussion Forum
farmall cub
dwood
10-10-2005 03:04:15
Kim,I checked out the two links you told me about.HOWEVER i FOUND NO MATCH FOR THE numbers i saw. The Number 51686 R2 is number I found to the left of the clutch, in raised letters on the block.The other number 5380 J is yhe number I found next to the steering box.like I said I found no match for ether number. Thanks Dan
chuck Bolton
10-10-2005 16:42:57
 Re: farmall cub in reply to dwood, 10-10-2005 03:04:15
you will find the serial number on a plate on the drivers side of the tractor--mine is pretty well worn off-- and sometimes the plate is missing-- it is not a cast number --it is stamped into the plate--
dwood
10-10-2005 15:19:58
 Re: farmall cub in reply to evielboweviel, 10-10-2005 03:56:11
Ron,thanks a lot,I will check it out
dwood
10-10-2005 15:17:20
dwood
10-10-2005 15:17:24
dwood
10-10-2005 15:17:31
